Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Walter Mautner on February 27, 2007, 2:08 pm
Please log in for more thread options Al Dykes wrote: .... However, the OP appears to have lost the thread. -- vista policy violation: Microsoft optical mouse found penguin patterns on mousepad. Partition scan in progress to remove offending incompatible products. Reactivate MS software. Linux 2.6.17-mm1,Xorg7.1/nvidia [LinuxCounter#295241,ICQ#4918962] | ||||||||||||||||||||||||||||||||||
Posted by Walter Mautner on February 20, 2007, 6:47 am
Please log in for more thread options davetonge@yahoo.co.uk wrote: > Hi
Most probably it is a autonegotiation issue. Try to set fixed speed/duplex
> > I am having some problems with a 40m CAT5 ethernet cable. > When I first installed the cable, I tested it and it was working with > no problems. I haven't used it in 10 months, and when I went to > reconnect it I am having a problem. The connection goes on and off > roughly once a second. So it will be on for one second, and then off > for one second - continuosly! > > What can cause this problem? > Could it be interference? > modes on both ends, or try to change one NIC/driver combo. -- vista policy violation: Microsoft optical mouse found penguin patterns on mousepad. Partition scan in progress to remove offending incompatible products. Reactivate MS software. Linux 2.6.17-mm1,Xorg7.1/nvidia [LinuxCounter#295241,ICQ#4918962] | ||||||||||||||||||||||||||||||||||
Posted by Wrolf on February 21, 2007, 8:01 pm
On Feb 19, 8:20 pm, daveto...@yahoo.co.uk wrote: > Hi
> > I am having some problems with a 40m CAT5 ethernet cable. > When I first installed the cable, I tested it and it was working with > no problems. I haven't used it in 10 months, and when I went to > reconnect it I am having a problem. The connection goes on and off > roughly once a second. So it will be on for one second, and then off > for one second - continuosly! > > What can cause this problem? > Could it be interference? > > Please help!!! > > Thanks > > Dave > daveto...@yahoo.co.uk Very difficult for it to be interference. Is it Cat 5, stranded, correct wiring (EIA/TIA 568B or 568A)? Try isolating the problem with a laptop, Fluke, or other Ethernet device. When you go through the cable, do you get the fault, or is it only with the user equipment? If only with user equipment, then that is the problem. Then move the test equipment to the other end of the cable, plug in to the switch or whatever is at the other end using the same patch cables. If you still have a problem, the cable is innocent. Only if the problem only occurs when the cable is in the path, blame the cable. If the cable is indeed to blame, the chop off BOTH ends, reterminate, and test with a tester. You should probably also test your tester against some known working good cable. Make sure you use the strain relief. If it still does not work, chop of BOTH ends, and run new cables. You might want to use the old cable as a wire drag, and get it out. Most of the time you just leave the old one in there, but you definitely want to chop off the ends to prevent accidentally using it. Wrolf | ||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Ethernet Cable Woes - On and Off every second | February 19, 2007, 8:20 pm |
| Ethernet cable shield | November 23, 2004, 5:02 pm |
| Firewire using on existing Ethernet cable | August 6, 2005, 7:36 am |
| Cable over ethernet for two Wireless access points | July 23, 2004, 6:57 pm |
| CAT-5 cable stuck in ethernet port - can't remove | April 26, 2006, 5:49 am |
| Re: Ethernet connection sensitive to cable length | May 3, 2008, 12:37 pm |
| DIY Ethernet | September 10, 2004, 8:57 pm |
| Ethernet cabling used outside | July 29, 2004, 7:57 pm |
| Cat 5 for phone and ethernet? | December 20, 2004, 9:57 pm |
| Cat 5 for phone and ethernet? | December 20, 2004, 9:56 pm |
| PoE and Ethernet switches | October 1, 2005, 10:22 am |
| Re: ethernet polarity | November 4, 2005, 10:44 pm |
| Cat 5e vs 6 and gigabit ethernet | February 4, 2006, 1:12 am |
| Re: ethernet and AC in same conduit | January 2, 2009, 8:47 pm |
| Gigabit Ethernet Cabling | November 17, 2004, 3:55 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
