LAN and Telecom Cabling Ethernet Cable Woes - On and Off every second
Subject Author Date
Ethernet Cable Woes - On and Off every second davetonge 02-19-07
Posted by glen herrmannsfeldt on February 20, 2007, 3:17 pm
Al Dykes wrote:
(snip)
> For properly wired cable, IMO, You'd have to be working right next to
> welding or high-power radio equipment to even *think* about
> interference.
Someone did post here in the past about running ethernet through
an arc welding factory.
While I agree that electrical interference doesn't seem likely,
there might be some possibility of mechanical effects, such as
vibration on a loose contact.
I still have not gotten around to testing 240VAC common mode
voltage on UTP ethernet to prove that it actually works.
I probably have enough disposable ethernet parts to do it.
-- glen
Posted by Al Dykes on February 20, 2007, 3:32 pm
>Al Dykes wrote:
>(snip)
>> interference.
All RJ45 ethernet connections are electrically isolated to (ISTR)
4,000V via coupling transformers. It's part of the spec.
You should be perfectly safe :-) Let us know how it turns out.
When UTP was new there was a paper published that described the
attempts made to induce errors in a UTP Ethernet connection. Copious
amounts of cable was wrapped around welders, fluorescent lights,
Microwave ovens, and Xerox copiers while BERT tests were run. The
error rate was essentially zero.
Over the years, UTP cable has only gotten better in it's ability to
reject induced energy.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore. A Proud signature since 2001
Posted by glen herrmannsfeldt on February 21, 2007, 5:44 pm
Al Dykes wrote:
(I wrote)
Safe, but it will be nice to see that it still works, too.
That depends some on getting it only as a common mode
voltage, which would be easy with center tapped transformers,
but they don't usually use them.
That is what I expect, but sometime I wanted to try it. I think
I have a transformer up to 208V, so I might only get that high.
-- glen
Posted by Dmitri(Cabling-Design.com on February 27, 2007, 12:37 pm
> interference.
> How do you know the "once a second" bit?
I agree with Al. These cables and associated equipment are usually pretty
resilient to interference. I think you should look into simpler issues
with the network configuration. There may be couple devices with the same
IP address on the same subnet or the equipment is trying to re-negotiate
speed or duplex mode or a similar networking related issue and not the
cable. Especially considering the regularity of the problem. Interference
issues tend to be random except of course when the source of EMI is
switched on and off regularly itself.
Best Regards,
Dmitri Abaimov, RCDD
http://www.cabling-design.com/
Home Cabling Guide, Cabling Forum, color codes, pinouts and other useful
resources for premises cabling users and pros
http://forums.cabling-design.com/ |
*** a better way to USENET *** |
| no-spam Web and
RSS interface to your favorite newsgroup |
24hoursupport.helpdesk,comp.dcom.cabling - messages and counting! |
Posted by Al Dykes on February 27, 2007, 1:45 pm
>> interference.
I still want to know ow the OP determined the "once a second" bit.
Similar ThreadsPosted
Ethernet Cable Woes - On and Off every second February 19, 2007, 8:20 pm
Ethernet cable shield November 23, 2004, 5:02 pm
Firewire using on existing Ethernet cable August 6, 2005, 7:36 am
Cable over ethernet for two Wireless access points July 23, 2004, 6:57 pm
CAT-5 cable stuck in ethernet port - can't remove April 26, 2006, 5:49 am
Re: Ethernet connection sensitive to cable length May 3, 2008, 12:37 pm
DIY Ethernet September 10, 2004, 8:57 pm
Ethernet cabling used outside July 29, 2004, 7:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:56 pm
PoE and Ethernet switches October 1, 2005, 10:22 am
Re: ethernet polarity November 4, 2005, 10:44 pm
Cat 5e vs 6 and gigabit ethernet February 4, 2006, 1:12 am
Re: ethernet and AC in same conduit January 2, 2009, 8:47 pm
Gigabit Ethernet Cabling November 17, 2004, 3:55 pm
