LAN and Telecom Cabling EMI Sensitivity of Coax and Twisted Pair wires
Subject Author Date
EMI Sensitivity of Coax and Twisted Pair wires Ralf Koenig 06-26-06
Posted by Ralf Koenig on June 26, 2006, 6:16 am
Hello,
I'm looking for a comparison that quantifies the effects of EMI
(electro-magnetic interference) on the following media:
UTP (Cat.3, Cat.5, Cat.7)
STP (Cat.3, Cat.5, Cat.7)
Coax RG-58 and RG-59
Fiber Optics
There are many qualitative statements on the web, that say that EMI
sensitivty decreases when going down the list mentioned above (in other
words: UTP is most prone to EM interference, fiber is least or not at
all prone to EM interference).
I'm looking for references, where I can find a table that gives concrete
values or value ranges, such as a book or a web site. Google came up
with a lot of results on related issues, none of them actually listing
concrete values.
Finally, some discussion which kinds of environments (engines etc.) may
cause interferences that affect data transfer via these cable, would be
most appreciated.
Thanks in advance,
Ralf
Posted by Dmitri(Cabling-Design.com on June 26, 2006, 6:40 pm
> Fiber Optics
I doubt you will find many reliable references let alone numbers. A test
like that is extremely hard to produce and maybe harder yet to verify.
Also, cabling manufactures are rarely if ever have access to equipment and
facilities required to conduct such tests, especially RF. I have seen
tests done (even took part in one many years ago) but the results were
very dependent on the environment the tests were conducted in.
The one I've assisted to conduct was strictly RF, so I would not
necessarily project the results onto low frequency noise from likes of
power cables and fluorescent lamp ballasts. However, for RF it boils down
to this: before your UTP (CAT5E and CAT6 - have not seen this done to
CAT3) cable will pick up enough noise your equipment -PC and pretty much
everything else - will fail (and people flee ;-)) because you are talking
way beyond FCC and EC allowed levels. You will never encounter such high
levels of EM fields in commercial and residential environments so there is
really no need to worry about the cable. Let me re-phrase that: worry
about the electronics before worrying about the cable.
If you are in a special environment (industrial, science lab, ship, plane,
spaceship etc.) - you are on your own. Feel free to conduct your own tests
and come up with your own results - no cable manufacturers will ever
guarantee anything or even conduct such (very expensive to setup) test.
As far as fiber is concerned, for all practical reasons there is no EMI
effect.
STP or ScTP will provide some degree of RF protection if properly grounded
on both ends which it never will due to ground loop concerns. It will not
provide any degree of protection for low-frequency EMI because most of its
energy is in magnetic component of the EM field and aluminum foils used in
STP are transparent to magnetic fields.
Coax cables are really for so different applications that I don't know why
would you even throw them into the mix, but all the STP considerations
apply here as well.
Best Regards,
Dmitri Abaimov, RCDD
http://www.cabling-design.com/
Home Cabling Guide, Cabling Forum, color codes, pinouts and other useful
resources for premises cabling users and pros
Article posted with
Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam Web and RSS interface to your favorite newsgroup -
comp.dcom.cabling -
2650 messages and counting!
Posted by Al Dykes on June 26, 2006, 8:13 pm
>> Fiber Optics
The EMI issue began when Ethernet over UTP was really new and I've
never known it to be anything but theoritical. I don't even recall
"CAT3" as a specification when I first put Cabletron hubs in service.
At the time somebody did some practial test, wrapping loops of what we
would call CAT3 cable around zerox machines,arc welders, small power
tools, etc, while running BERT tests. As I recall, the BERT error
level was ZERO. I don't think I've ever heard of EMI-induced errors in
commercial use of UTP. If I were installing a network near an MRI
machine or near an electric arc furnace I'd use fibre, but I'd have
lots of other issues, too.
Even if there were an occasional noise shot, A TCP/IP network would
resend the packet very nicely, thank you.
UTP cable is twisted pairs of wire. One byproduct of that is that any
external EM field that would induce voltage in one wire induces an
identical, opposite voltage in the other wire of the pair. They cancel
out. For perfectly symetrical pairs EMI induces zero net voltage.
As I understand things, UTP wire, in each step from CAT3 to CAT 6 has
improved the exactness of the twists. This makes CAT6 much more
EMI-resistant than CAT3, especially what was in use when the tests I
recall were done.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore. A Proud signature since 2001
Posted by Robert Redelmeier on June 27, 2006, 9:11 am
> CAT 6 has improved the exactness of the twists. This makes
> CAT6 much more EMI-resistant than CAT3, especially what
> was in use when the tests I recall were done.
AFAICS, Cat3 to Cat5 was an improvment in EMI (all twists
much tighter), but since then, most of the improvements have
been to reduce crosstalk (twists slewed). I think Cat5/5e/6
are all pretty much the same for external EMI, although some
of the siamesed-pairs might be slightly better.
-- Robert
Posted by David Lesher on June 28, 2006, 9:20 am
Neither Coax or UTP is sensitive to EMI.
Their terminating electronics, may be, however. That's a function
of many factors, none easy to generalize about.
A host is a host from coast to coast.................wb8foz@nrk.com
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Similar ThreadsPosted
EMI Sensitivity of Coax and Twisted Pair wires June 26, 2006, 6:16 am
S-Video to Twisted Pair keystone adapters March 19, 2007, 11:10 pm
How to RJ-45 with 3 pair (6 wires) cable August 16, 2006, 8:46 pm
four twisted pairs to RJ4 November 4, 2007, 5:27 pm
what are the extra cable wires for May 25, 2005, 9:16 pm
10BaseT over RG6 Coax July 31, 2008, 11:19 am
Can I use somehow use CAT5 instead of COAX for SPDIF? October 11, 2004, 8:24 pm
Coax Grounding Requirements January 29, 2006, 9:58 pm
Extending coax cause signal loss? April 8, 2005, 11:02 pm
How to crimp RCA connectors onto RG59 coax July 11, 2006, 4:12 pm
Convert old Coax RG59/6 to Cat 5 while wiring house -- possible? September 4, 2004, 2:16 pm
Can I use a CAT5 cable as a TV Coax cable? October 14, 2006, 2:13 pm
Which pair should i choose.? February 7, 2006, 3:42 am
terminating 25 pair cable July 18, 2004, 12:08 am
Is cat. 5e cable available in 50 pair, 100pair ? November 4, 2004, 9:25 am
