LAN and Telecom Cabling Creating a new network with cabling and wall outlets in 2 buildings
Subject Author Date
Creating a new network with cabling and wall outlets in 2 buildings L. Hummel 06-14-05
Posted by L. Hummel on June 14, 2005, 9:17 am
Hi everybody,
I am quite new to networking, and I need to set up a network of PCs spread out
on two buildings. Building 1 is with 4 floors, and Building 2 with a single
floor.
I want the cabling to be based on wall outlets, with one 2-connector outlet at
each of the floors in Building 1, except on the top floor where only a single
outlet is needed. In building 2 I want one 4-connector outlet (or two
2-connector outlets). I have made a topology diagram below:
Building 1 Building 2
Floor 2 PCs Wall outlets
| |------|| 1 ||
Floor 1 |
| |------|| 1 | 2 || ------- -------
Floor 0 | \ /
| |------|| 1 | 2 || || 1 | 2 | 3 | 4 ||
Basement | | Subnet 192.168.0.0
| |------|| 1 | 2 || ------| |
| | Subnet 192.168.1.0
|Cable modem|---|Firewall/Switch|
The network should connect to the Internet via a Cable modem and a Firewall/
Switch of the type 3Com® OfficeConnect® VPN Firewall (details can be found
on the following link) :
http://www.3com.com/prod/en_UK_EMEA/detail.jsp?tab=features&sku=3CR870-95
Inside the Firewall, the network is equipped with a 3Com® OfficeConnect®
Gigabit Switch 5 - described on the following link:
http://www.3com.com/prod/en_EU_EMEA/detail.jsp?tab=features&sku=3C1670500A
Now, the question is: How do I construct this network with the fewest
possible cables running - especially between the two buildings? How do I
interconnect the wall outlets? Besides the normal STP cables as well as
the connectors for the wall outlets, what hardware is needed?
I appreciate any answers. Thanks in advance.
Best regards,
L. Hummel, Denmark
Posted by Justin Time on June 14, 2005, 10:02 am
For between the buildings, use fiber with an Ethernet switch to drive
the station cables. Two cables to each workstation outlet should be
the minimum. I recommend 3, one phone, one dedicated to Ethernet and
the third that can be used for either voice or data. You never know
when you are going to need a second phone line or a networked printer
in a space that has its network and phone cables in use. Besides,
cable is relatively inexpensive - it is the labor to install,
terminate, and test that is the expensive part of any installation.
Oh, for the fiber, a minimum of 6 strands, even if you only use two,
you never know when you will need more capacity or have more
applications that have to flow between the buildings.
Rodgers Platt
Posted by Al Dykes on June 14, 2005, 1:04 pm
>Rodgers Platt
Why did you delete the OP question ? There is more and more of this
recently all over Usent. I suspect the new verison of some software
has this as a default. Nothing personal.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Posted by Justin Time on June 15, 2005, 9:47 am
Al,
I didn't delete anything. I just clicked on reply - as I did with your
message - using Google Groups.
Posted by Al Dykes on June 15, 2005, 1:19 pm
>Al,
Well, it's not including the message you are responding to and that is
not good,
What software are you using ?
Similar ThreadsPosted
Creating a new network with cabling and wall outlets in 2 buildings June 14, 2005, 9:17 am
Temporary aerial cabling tween buildings- Arnco flex tubing? February 3, 2005, 8:13 pm
Fishing one network cable in wall? November 4, 2004, 6:01 pm
Wall mount network jacks October 6, 2005, 10:55 am
Need advice for a wall-mounted patch panel for home network January 17, 2006, 10:34 am
Complete Solution for creating your own Voip business December 15, 2006, 8:04 am
Ontario Network Cabling Exam October 1, 2004, 1:39 pm
Dishnetwork as part of a structured cabling network March 30, 2005, 11:41 pm
802.11G health issue and home network cabling question September 25, 2006, 8:32 pm
Wiring on RJ45 wall socket July 8, 2007, 6:22 am
Cat5 phone wall plates with post July 1, 2005, 11:40 am
Cat6 Patch Panel in Wall Enclosure August 9, 2005, 8:34 pm
Newbie question re connecting wall sockets November 10, 2006, 12:24 pm
Allen Tel hinged wall mount bracket screws September 30, 2004, 2:48 am
Network in new house June 12, 2005, 6:48 pm
