Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by djenka2 on September 14, 2006, 3:43 pm
Please log in for more thread options I am planning to make a home network in already finished house. I was wondering if it's OK to partially fish cat5e cable thru heating/cooling dusct pipes (in order to make the least possible damage and drilling)? If it's not OK, is there a solution by buying some kind of shield or something so I can wrap network cable in to protect it from heat/cold? Thanks | |||||||||||||||||||
Posted by DLR on September 14, 2006, 6:02 pm
Please log in for more thread options djenka2 wrote: ever burns down, your insurance might not pay. Unless you're on a slab with a flat roof, well it can be a pain but get used to it. :) | |||||||||||||||||||
Posted by Dmitri(Cabling-Design.com on September 14, 2006, 11:47 pm
djenka2 wrote: > I am planning to make a home network in already finished house. I was
> wondering if it's OK to partially fish cat5e cable thru heating/cooling > dusct pipes (in order to make the least possible damage and drilling)? > If it's not OK, is there a solution by buying some kind of shield or > something so I can wrap network cable in to protect it from heat/cold? Not a good idea at all. You will probably do more damage to the ducts themselves pulling the cables through them. Additionally, how do you neatly get in and out of a duct with a bundle of cables without compromising air distribution that the ducts were designed for? Also, think of upcoming duct cleaning ;-) well, maybe not this year but in a couple years time you might want to get them cleaned and you don't want cables on the way. It needs a plenum cable that's about 3 times more expensive than PVC that you could have put in the walls. I would say it would be (much) easier for you to patch walls than ducts. On top of that, do some social engineering at home: ask your significant other if she (he?) wants that wall painted. The answer is almost always 'yes'! This way you get full access to the wall(s) you need outlets on and a nice paint job over your patch (if required) when all is set and done. -- Best Regards, Dmitri Abaimov, RCDD http://www.cabling-design.com/ Home Cabling Guide, Cabling Forum, color codes, pinouts and other useful resources for premises cabling users and pros -- +----------------------------------------------------------+ | http://forums.cabling-design.com/ | | *** a better way to USENET *** | | no-spam Web and RSS interface to your favorite newsgroup | | comp.dcom.cabling - 2913 messages and counting! | +----------------------------------------------------------+ | |||||||||||||||||||
Posted by djenka2 on September 15, 2006, 10:12 am
OK, thanks guys. I don't want to run cables through the ducts but what if I just drill the hole besides the duct but so close that the grill (register) will cover it (to use the same plywood cut/openning). It that case the cable whould be totaly outside of the duct. Do you think that's safe? Thanks DmitriCabling-Design.com wrote: > djenka2 wrote:
> > wondering if it's OK to partially fish cat5e cable thru heating/cooling > > dusct pipes (in order to make the least possible damage and drilling)? > > If it's not OK, is there a solution by buying some kind of shield or > > something so I can wrap network cable in to protect it from heat/cold? >
> > Not a good idea at all. You will probably do more damage to the ducts > themselves pulling the cables through them. Additionally, how do you > neatly get in and out of a duct with a bundle of cables without > compromising air distribution that the ducts were designed for? > > Also, think of upcoming duct cleaning ;-) well, maybe not this year but in > a couple years time you might want to get them cleaned and you don't want > cables on the way. > > It needs a plenum cable that's about 3 times more expensive than PVC that > you could have put in the walls. > > I would say it would be (much) easier for you to patch walls than ducts. > > On top of that, do some social engineering at home: ask your significant > other if she (he?) wants that wall painted. The answer is almost always > 'yes'! This way you get full access to the wall(s) you need outlets on and > a nice paint job over your patch (if required) when all is set and done. > > -- > > Best Regards, > Dmitri Abaimov, RCDD > http://www.cabling-design.com/ > Home Cabling Guide, Cabling Forum, color codes, pinouts and other useful > resources for premises cabling users and pros > > > > -- > +----------------------------------------------------------+ > | http://forums.cabling-design.com/ | > | *** a better way to USENET *** | > | no-spam Web and RSS interface to your favorite newsgroup | > | comp.dcom.cabling - 2913 messages and counting! | > +----------------------------------------------------------+ | |||||||||||||||||||
Posted by Robert Redelmeier on September 15, 2006, 10:44 am
> ducts but what if I just drill the hole besides the duct but > so close that the grill (register) will cover it (to use the > same plywood cut/openning). It that case the cable whould > be totaly outside of the duct. Do you think that's safe? It is safe, but likely unsightly. It sounds like you're up North with a basement/crawlspace and force-air outlets in the floor for heating. (The South has no basements and puts outlets in the ceilings for AC). If you're going to run cabling in the basement/crawlspace, the best way is to locate the interior walls (no insulation, best to avoid plumbing), and drill upwards through the subfloor and sole-plate into the studspace. Push cable up and grab from holes cut in drywall for crimp-on low-voltage boxes. Cover with wallplates and jacks. If you have to do a second-story, it's best to find a basement-to-attic chase and drop the second story cables from the attic. Sometimes you can go through closets. -- Robert | |||||||||||||||||||
| Similar Threads | Posted |
| Cat5e cable running thru duct pipes??? | September 14, 2006, 3:43 pm |
| I respect this group's input: New to cabling : - Running cables from attic down walls | December 21, 2006, 9:36 pm |
| How big a duct for future wiring? | March 30, 2005, 1:30 pm |
| Use CMR or CMX rated cat5e cable | February 12, 2007, 7:56 pm |
| Can Cat5E UTP cable be exposed to the outdoors, or burried? | October 3, 2006, 10:50 am |
| Sell Cat5e FTP Patch Panels,Cat 5e FTP Patch Panels,Cat5e Shieldes Patch Panels | March 15, 2006, 8:23 am |
| Extending cat5e - Help! | August 6, 2005, 4:20 pm |
| CAT5e Jacks | February 3, 2006, 8:44 am |
| telephone connection with cat5e | July 13, 2005, 10:40 am |
| Multiple T1 transmissions on Cat5E | August 7, 2005, 7:36 pm |
| Long Cat5e runs | February 13, 2006, 8:42 am |
| CAT5E and Romex (Electrical) | February 17, 2006, 11:31 am |
| toolless cat5e jacks | April 8, 2006, 1:50 am |
| Straight-through CAT5E cabling | April 22, 2008, 6:07 pm |
| Shielded Cat5e for Gigabit Ethernet | September 14, 2004, 9:35 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thanks
