LAN and Telecom Cabling ADSL over CAT-5e?
Subject Author Date
ADSL over CAT-5e? John Carlyle-Clarke 03-09-05
Posted by John Carlyle-Clarke on March 9, 2005, 2:00 pm
I'm in the UK and I have an ADSL-enabled BT line coming in next to the
patch panel for a Cat 5e cabled office. Can I extend the ASDL to
another part of the office over the Cat 5?
I suppose I'd need by the patch panel a BT plug -> RJ45 conversion ..
not sure how I would achieve this? Then at the other end, an RJ45 ->
BT socket conversion, which is easy enough. Then I'd plug in the
filter and the modem.
Would this work?
Posted by James Knott on March 9, 2005, 12:38 pm
> Would this work?
I'd recommend putting the filter in first, then running the separate phone
and ADSL lines as needed. Another possibility, would be to put the ADSL
modem near the line and then run ethernet from it, to where you need it.
Posted by Petri Krohn on March 9, 2005, 6:06 pm
Doesn't anybody in the UK use structural cabling for telephony?
Structural cabling = Using the same type of Cat-5 cable + RJ-45 sockets for
telephone, Ethernet, whatever...
The telephone signal would go on the blue/white pair on pins 4 and 5.
UK phones seem to use an extra wire for the ringer. Is this still in use in
modern phones? Which pin/wire would this go on?
> Then I'd plug in the filter and the modem.
You only use a (low-pass) filter to block the ADSL high frequencies from
reaching the POTS phones. For connecting a modem you do not need a filter
> Would this work?
Yes. Cat-5e cable is just a better version of twisted-pair telephone cable.
(The really interesting question is whether and when you can run 100 Mbps
Ethernet over normal phone wires.)
(Copy to news:uk.telecom.broadband, follow-ups to news:comp.dcom.cabling.)
Petri Krohn
Helsinki Neighborhood Networking Association
HelsinkiOpen -- http://www.helsinkiopen.net
Posted by Paul D.Smith on March 9, 2005, 4:27 pm
As per previous poster, yes. One option is to use a NET5 adapter from
http://www.clarity.it to get at the ADSL on its own and then wire this into
your structural cabling.
To answer the other poster's questions, yes, the third "ring the bell" wire
is still required.
Almost nobody has structural cabling in our homes. People use various
standards of telephone cable for phones. Typically this will carry the ADSL
signbal as far as it needs to go.
Paul DS.
Posted by John Carlyle-Clarke on March 9, 2005, 8:01 pm
> viestissä
>> to the patch panel for a Cat 5e cabled office. Can I extend the
>> ASDL to another part of the office over the Cat 5?
> sockets for telephone, Ethernet, whatever...
The telephony is done this way - there is an ISDN 2 line and a
digital exchange. The ADSL line however just terminates on a
standard BT master wall socket at the moment.
>> conversion .. not sure how I would achieve this? Then at the
>> other end, an RJ45 -> BT socket conversion, which is easy enough.
> 5. UK phones seem to use an extra wire for the ringer. Is this
> still in use in modern phones? Which pin/wire would this go on?
They do use this, but in a structured cabling environment, the
splitting from 2 to 3 wires is usually done in an adapter between
the RJ45 wall plate and the phone handset, if required.
> frequencies from reaching the POTS phones. For connecting a modem
The use of the filter would really be for jack compatibility. The
filter also serves the purpose of converting between a BT type
telephone socket and an RJ-11 socket which most ADSL modems require.
>> Would this work?
> telephone cable. (The really interesting question is whether and
> when you can run 100 Mbps Ethernet over normal phone wires.)
I thought this was true, but I didn't want to assume.
Thanks for your reply, and to the other posters too! A few
different approaches to choose between..
Similar ThreadsPosted
ADSL over CAT-5e? March 9, 2005, 2:00 pm
How to Rack a Netgear DG632 ADSL Modem Router March 5, 2007, 8:22 am
Connecting an ADSL gateway to an ethernet port that connects to a patch panel July 14, 2006, 5:00 pm
Supply Telephone Accessories,Modular Adapters Couplers,Duplex Jack,Triplex Adapters,ADSL Adapters,Plug With RJ12 Jacks November 9, 2005, 11:52 pm
Sell Cat5e FTP Patch Panels,Cat 5e FTP Patch Panels,Cat5e Shieldes Patch Panels March 15, 2006, 8:23 am
Extending cat5e - Help! August 6, 2005, 4:20 pm
CAT5e Jacks February 3, 2006, 8:44 am
telephone connection with cat5e July 13, 2005, 10:40 am
Multiple T1 transmissions on Cat5E August 7, 2005, 7:36 pm
Long Cat5e runs February 13, 2006, 8:42 am
CAT5E and Romex (Electrical) February 17, 2006, 11:31 am
toolless cat5e jacks April 8, 2006, 1:50 am
Use CMR or CMX rated cat5e cable February 12, 2007, 7:56 pm
Straight-through CAT5E cabling April 22, 2008, 6:07 pm
Shielded Cat5e for Gigabit Ethernet September 14, 2004, 9:35 pm
