Could someone give me a technical reason why, when I connected a cable modem and three computers to a hub, it was faster than connecting a cable modem and three computers with a switch?
I know that routers are the solution, but I am in a debate and am drawing on my past experience. For example, when using a packet sniffer, you want to be a part of the same collision an broadcast domain. You can do that with a hub, but you can't with a switch.
It must be the same principle when you only have 2 or 3 computers on the same network and collisions are not a problem. Am I right and if I am, could someone explain why?
TIA
