Web-based traceroute
Is there a web-based site where I can do a traceroute by entering the originating IP address and the destination IP address? I've got a set-top box (MSNTV2) which doesn't have access to "command prompt".
chichashaman
If there was, it would trace the route from the hosting site to the destination, probably not what you want.
Tom Stiller
Try this site:
Not sure about entering an originating IP other than your own though
Jbob
Try some of the sites listed at
Not all are active any longer, however. I also don't think you get the option of entering originating IP address (originating will be the server/router you are triggering the trace from), but some do let you specify destination (most just trace to the IP you are connecting from).
Jimbo
