Hi- We have a Toshiba PCX5000 cable modem/wireless router combo. The wireless portion fucntions fine, and we receive a strong signal anywhere we want to use our machines. However, the cbale input/output seemingly fails quite often. That is, the "cable" light goes out and we lose connectivity. The only fix I can find is to reboot the device by unplugging it, and this works ~50% of the time (and never on the first try). Otherwise, we just have to wait unitl the thing decides to pick up the cable feed again. I've tried to eliminate some variables and have determined:
- It is not the coaxial cable itself.
- It is not the styrength of the cable signal at this particular jack or in our house overall.
Has anyone experienced similar problems? Any remedies? Unfortuantely I do not have a receipt for the modem, so if anyone has experience with Toshiba warranty/exchanges that might be helpful too.
Cheers,
Drew
