I'm about to get cable/broadband and wanted to know if I can split my wires coming from the modem with out using a router? I want to run a line to my playstation 2 and my computer. I wouldn't be using them both at the same time but what would happen if I did? just kinda curious. and yes I know I'm being cheap and should just buy a router.
You can't just split an Ethernet line. You would at the very least need a hub.
If you chose not to pay for two IP addresses, depending upon your cable company you may be able to just power-cycle the cablemodem when you want to switch devices, or you might have to call in to have them manually change your account each time you change devices.
You might also find, depending on your cable company, that they'll let you have both devices connected at the same time, and take that as an indication that you want to sign-up automatically for an additional IP address, and they'll oblige by automatically billing you for that second IP address.
All in all, you're best off just buying the router. You would also have the added protection of the router acting as a firewall to protect both your computer and Playstation. Not getting a router may be pennywise and dollar foolish.
You can get a Netgear or Linksys router/switch for like $30 or less after rebate (another $10 will get you a wireless G-router). Look for a sale in Sunday papers at the usual electronics places. It will be worth more than the $20-40 you may pay in the long run just in keeping worm/virus attacks off your computers.
