Well I am not trouble free however......... :-)
I do have a few channels on my TVs that I get bleedover from some local stations. I understand that and accept it knowing how many sets I have connected. FWIW, all the wiring was done by me. I purchased my own roll of RG-6, connectors, etc and did it all myself. The one thing I want to change is getting rid of crimp on connectors and going to compression ones. I just need to find a supplier either locally or order online. Eventually I will wire in a power amplifier to power the whole house except for modem of course and have an individual line to each set location.
When I first bought this house less than two years ago a new drop was run to my home. They were just out this past week and again replaced it as it was verified as bad again. They were called for a tv signal problem but internet was fine. I thought that might clear up my internet issue but it didn't
I am having trouble with my internet connection but it is kinda peculiar. I am on Comcast Gold tier(6000/768). My download speeds are very good. Routinely at 5500+ down with over 6000 quite often however my upload speeds seem to suffer extremely bad at random intervals. I have checked my speeds using various machines, with/without router, and with various OSs even testing using a Knoppix Live Boot CD. I have swapped modems (3 different ones) with no fix. Had a tech show up only to say not much he could do. I know more than him. lol Many times it's as if a switch is thrown and my upload speeds go back up to normal. I test using several SpeakEasy test sites but most of my upload test are done using WS-FTP LE and uploading a file to my Personal Web Space on Comcast. I verify speeds using the upload dialog in WS-FTP and also monitor using the small utility NetPerSec from PCMag. It appears that there is no issue at my home and I am guessing the problem is something with Comcast whether it is with my lines locally or something with the config file that is pushed to my modem from Comcast.
I am in the process of finding other local users to see if they suffer from the same issue to either verify it is something locally to me or others as well.
So my main reason for asking my original question was to see if it might help by what I had suggested. In reading some other posts on DSLReports it seems I might be better off running my modem off a 2-way and then using another 2-way to go between the upstairs and downstairs sets. Although my modem signal strength appears fine, any little bit might help.
