Hi, not sure if anyone else has this problem;
I am using a RCA cable modem model DCM425 (COMCAST
connection)connected to a LinkSys Wireless-B 2.4 Ghz router
supporting 2 computers.
Periodically, in ~1 week the modem's internet connectivity will die.
I know the modem is still receiving full signal since the USB port
still works at full capacity. It is only after I reset the modem
that the ethernet port regains internet connectivity. Resetting the
modem is easy enough but every time the modem is reset the router
also has to be reset through a relatively lengthy process.
I'm just wondering why the modem dies and whether it is a hardware or
sofware problem
Thanks
