I JUST got cut off (a few minutes?) again:
Cable Modem Downstream Downstream Lock : Locked Downstream Channel Id : 71 Downstream Frequency : Downstream Modulation : QAM256 Downstream Symbol Rate : 5360537 Downstream Interleave Depth : 32 Downstream Receive Power Level : -1.9 dBmV Downstream SNR : 35.7 dB
Here is what I saw BEFORE I got cut off: Downstream Lock : Locked Downstream Channel Id : 71 Downstream Frequency : Downstream Modulation : QAM256 Downstream Symbol Rate : 5360537 Downstream Interleave Depth : 32 Downstream Receive Power Level : -2.1 dBmV Downstream SNR : 35.3 dB
I used my fingers until I couldn't turn screw anymore on the cable modem. Using a wrench or something else sounds a bit extreme to me. ;)
I didn't see anything odd while wiggling, soft bending/flexxing, etc. on the cable connected to the modem.
