Possible to use Agent to get to Charters newsgroups thru Bellsouts dsl?
Threaded View
I was wondering if its possible to get to my Charter news groups thru
the Bellsouths dsl while Im at work which is behind a router?
Re: Possible to use Agent to get to Charters newsgroups thru Bellsouts dsl?
That's up to Charter.  You'll have to check with them if they allow access
to their news servers from an outside connection.
mady
Never argue with an idiot. They drag you down to their
level, then beat you with experience.
Honi soit qui mal y pense
Generally speaking, the answer will lie in the answer to this
question. Do you have to login to Charter's Usenet server with a
username and password? If you do, you may very well be able to use
them with a BellSouth connection. If you don't, which I'm betting is
the case in your situation, you can't because Charter authenticates
you based on the IP address assigned to your Internet session. If it's
outside Charter's range of assigned IPs, you won't get access.
Site Timeline
