Netgear WGR614 v.5 wireless router, with latest firmware. I'm trying to set up reserved LAN addresses for three machines. So, under "LAN IP Setup", I followed the directions to do so, giving, e.g., one machine
192.168.1.10, the device name the machine's hostname, and the correct MAC address. I run Linux, so I restarted /etc/init.d/net.eth0. However, upon dhcpc getting an IP from the router, I get, e.g., 192.168.1.4, not .. .10. The router will not allow me to set a reserved address outside the range set under "Use Router as DHCP Server", which is the default, .2 to .51. If anyone has any hints or pointers, I'd really appreciate it. Thanks.- posted
18 years ago
