If I am posting in the wrong group, please let me know.
I have a Linksys BEFSR11 Cable/DSL Router. Up until yesterday, I was using a Linksys EFAH08W 8-port hub to share this connection to several computers. That worked fine.
I am planning to add more PCs to my network, so I needed something bigger than the 8-port hub. I decided to go with the Linksys EZXS16W
16-port switch. That gave me plenty of ports and the added benefits of a switch (instead of a hub).Unfortunately, now I am having problems.
With the switch, I lose the connection to the router (and thus the WAN) frequently -- say every 20-30 min. When this happens, I can't even bring up the web admin interface for the router from inside the LAN. Restarting the switch does not seem to help. Oddly enough, restarting the router is all that seems to fix it.
After stuggling with this issue all morning, I took out the switch and put my hub back in. Now it seems fine again.
Some other details that might help:
On the router, I was a little confused about whether to use the "X" or "||" (crossover or straight-thru) setting for the uplink port. The manual seems to indicate the straight-thru setting for a switch with a cross-over uplink port (which the switch has, I think). But it seemed to behave exactly the same no matter how I set this on the router. I am using a straight-thru cable.
Also, I have the MDI/MDIX setting on the switch depressed, which should be the correct setting. According to the docs, "To utilize the port's uplink capability, the MDI/MDIX button must be depressed. If the button is not depressed, port 16 will function as a normal 10/100 port."
