In the Capital District, Time Warner lets you have 3 unique IP addresses. I have been using a DLink Wireless router for a while with success. I plugged the cable modem into the WAN jack of the router, then plugged my PC into the router. Two other PCs in the house had wireless cards and got to the internet that way. Time Warner assigned the router its IP address, and the router used DHCP to assign IP addresses to all the computers in the house. Also, we were all able to use Windows networking to share printers and files.
Here's my question: with RoadRunner, does each IP address get a fixed amount of bandwidth? In the case I outline above, are all of our computers sharing the same pipe? The reason I ask is that I just picked up Vonage service and I'm thinking that I could plug the cable modem into a hub, then plug the router into the hub and the Vonage box into the hub. All of our PCs would still be plugged into the router, but the Vonage box would get its own IP from RoadRunner and, I am hoping, its own bandwidth so that it wouldn't fluctuate based on what we were doing on our PCs.
If that works, I may just unplug my PC from the router and put it into the hub to leverage the three IPs that RoadRunner provides so that my PC could get maximum bandwidth while the wireless PCs would have their own pool. Only problem then is that I'm thinking our home networking would get screwed up since my PC would be outside of the router. :( Thanks for any help you can provide!
Lerch
