Tweak Test Service:dsl Speed (advertised) kbit/s: 10 Mbps Operating System:winXP Connection:winXPpppo
- Your Tweakable Settings: Receive Window (RWIN): 17280 Window Scaling: off Path MTU Discovery: ON RFC1323 Window Scaling: OFF RFC1323 Time Stamping: OFF Selective Acks: ON MSS requested: 1440 TTL: (less any hops behind firewall)
- Test 1024001 byte download Actual data bytes sent: 1024001 Actual data packets: 713 Max packet sent (MTU): 1480 Max packet recd (MTU): 1480 Retransmitted data packets: 0 sacks you sent: 0 pushed data pkts: 114 data transmit time: 3.511 secs our max idletime: 230.0 ms transfer rate: 268398 bytes/sec transfer rate: 2147 kbits/sec This is not a speed test! transfer efficiency: 100%
- ICMP (ping) check Minimum ping: 35.67 ms Maximum ping: 38.09 ms Ping stability:
Notes and recommendations: Check FAQ on MTU for XP (FAQ #2252) Choose RWIN between 95040 and 250560 (FAQ #586) download/use DRTCP .. (FAQ #578)
SPEED TEST
187.4 kilobits per secondCommunications 187.4 kilobits per second Storage 22.9 kilobytes per second
1MB file download 44.8 seconds Subjective rating MediocreDate & time Wednesday, April 26, 2:35PM* Test type IDT4 Free Connection type ADSL Region Ontario Data size 1024KB IP address XXXXXXXXXXXX Provider
Comparison Your speed ADSL in Ontario (avg. 1.32 Mbits/sec) T-1 (max. 1.54 Mbits/sec)
