I've got a new PC, running XPand I'm having no success in getting this box on the network.
The router is a Linksys BEFSR41 , 4 port wired router. There's two other machines on it, on running win98 and another XPbox.
The new machine plays fine on the net, IF you feed the output of the cable modem directly into the network card on the new XP PC. If you put the cable modem feed back into the router, the network works fine for the other 2 machines, but the new XP box , now hooked to the router, doesn't see the network I can take another PC, and plug the network feed out of the router that did NOT work with the XP box, plug it in, and other PC works fine. Re-hook up new XP box, and again, no go (it wont load an IP address).
I'm running out of ideas. All previous machines with this router have been plug and play, and indeed this new PC works fine...as long as the router isnt between it and the cable modem.
Anyone have any suggestions? I'm running out of ideas.
Thanks! J. =-=-=-=-=-=-=-=-=-= X-No-Archive: Yes
