Q: How do I get the maximum possible DSL or cable modem speed? Should I use one of those tweaking programs?
A: See the Navas Cable Modem/DSL Tuning Guide at .
John I hope you can share your question and answer with the group at "unlockingmodems-com"
Google "Cablenut"! It's a exe file that uses a given "ccs" file to modify your registry. Than Google the "Shifter Custom.ccs file. These files are available on two different sites.
Just run the program and use the Shifter Custom file. It will make 38 entries in your registry if you choose to use it. It also gives you the option of backing up your registry if you choose. I recommend that you do.
It worked for me.
Good luck.
