Cable Modems distance between cable socket and modem
Subject Author Date
distance between cable socket and modem Nima Rezai 06-27-08
Posted by Bill M. on June 27, 2008, 6:27 pm
On Fri, 27 Jun 2008 23:57:49 +0300, henry999@eircom.net (Henry) wrote:
>> Not joking. I have 4 installs of experience since starting with cable
>> modem in 98. All 4 times, the installer verified signal/noise
>> downstream signal strength and upstream required gain at the inside
>> jack where the modem was to be installed.
>Interesting. Here you go to the ISP's office and they give you the
>cablemodem, after scanning the MAC address. By the time you get home
>they have programmed their system to recognise that device at your
>residence so when you connect everything together and turn it on, it
>syncs up and away you go. It just works. For those people who can't hook
>it up themselves, they will send a tech but it costs an arm and a leg.
I'm not trying to be mean or rude, but it sounds like you may have
done a self install. That would explain the 3 splitters in series. I'm
glad it works as well as it does.
Bill
Similar ThreadsPosted
distance between cable socket and modem June 27, 2008, 7:32 am
distance between power and communication cablel February 10, 2005, 4:13 pm
Save On Long Distance Get VOIP internet phone service Marketers needed November 15, 2005, 4:02 pm
Using Cable Modem and DSL Modem at the same time November 10, 2004, 12:47 am
Cable modem not working with TV cable plugged in November 2, 2006, 1:34 am
My cable modem is down August 15, 2004, 2:08 pm
Re: My cable modem is down August 28, 2004, 7:31 am
Do I need a new cable modem? February 15, 2005, 3:00 pm
what cable modem to ge March 30, 2005, 10:15 am
cable modem November 21, 2005, 9:55 pm
cable modem May 14, 2006, 9:52 am
Cable Modem September 15, 2007, 10:06 am
Cable modem in apartment September 22, 2004, 10:58 am
Printing via cable modem and vpn September 24, 2004, 10:42 pm
Cable modem slowing down with use?? November 11, 2004, 8:46 pm
