Cable Modem purchase
My old Motorola SB 4100 died a few days back. Does it really matter what brand/model of modem to buy? Walmart has the Motorola SB 5120 for around $54.00 OR I can buy a used WebStar from my cable co. for around $30.00. Is one any better?
Thanks Kevin
KissFan
I'd go with the Motorola SB 5120 (or the SB 5100). Overall it gets the best reviews of any out there.
Dave
What he said!!!
CIAO!
Ed N.
Dave wrote:
Ed Nielsen
Before buying anything, you should check with your cable co. and see what they allow.
cheers,
Henry
Henry
Thanks and I did. They will allow the Motorola SB5120 which my local Walmart sells.
KissFan
