If i split the cable modem signal would this effect the speeds of my internet?
TIA
ALi
TIA
ALi
Not if the resultant signal is adequate for the modem. Read the modem's received signal strength before and after the split.
thanks
Short answer: it depends.
After the split, if you still have enough signal strength at the modem, and the additional devices you're connecting aren't feeding a bunch of noise back into the cable, you should be fine. Modems either work or they don't. They don't get faster or slower with varying signal strength.
OTOH, if after the split your signal strength at the modem is too weak to maintain a connection, then you may not be able to connect at all or you may not be able to stay connected. If you can't stay connected, I'd say your speeds are affected.
Depending on your modem, there may be a web page at http:192.168.100.1 that will tell you your current downstream signal level. Subtract about 3.5 from that and see if you'll still be in the range of -15 to
+15, and ideally not near one of those ragged edges.While you're looking at the modem's signal strength, if you can, look also for the downstream signal to noise ratio and the upstream signal strength. If you find that you have connection problems later, we'll want to know what those values are.
