ADC Multimodem 701g (mm701g) Serial Cable Schema
Threaded View
Does anyone have a valid schema for the Serial Cable for this device? (Its
Rj45->DB9). For some reason I can't google the schema, and all my standard
cables dont want to work with this device.
Thanks for any help.
Mariusz Drozdziel
Re: ADC Multimodem 701g (mm701g) Serial Cable Schema
On Tue, 9 Aug 2005 13:32:18 +0000 (UTC), Mariusz Drozdziel
A continuity tester should help you make sense of it in short order,
considering the small number of conductors.
Bill
Cable pinout is available at
http://www.adc.com/documentationlibrary/technicalpublications /
do a search for User Manual part number 1187627
Console port pinout is on page 86 of the manual (page 92 of the
..pdf doc)
--reed
Site Timeline
