Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Marc on May 26, 2005, 7:23 am
Please log in for more thread options Is there anyway to make a wireless PCI network card stop hogging the CPU? | |||||||||||||
Posted by $Bill on May 26, 2005, 4:05 am
Please log in for more thread options Marc wrote: > Is there anyway to make a wireless PCI network card stop hogging the CPU?
How does a card hog CPU ? My task manager only shows processes using CPU. If there is a process talking to the card and it's using a lot of CPU, you could lower its priority if you think it won't have adverse affect. | |||||||||||||
Posted by Basic Bob on May 29, 2005, 3:38 am
> Is there anyway to make a wireless PCI network card stop hogging the CPU? > > > Sure, if you are the designer, there are three things: chipset, firmware, and driver. For the rest of us, the best you can do is pick a card which does not hog the CPU. Generally, the fastest cards do more work right on the NIC so there is less for the CPU to do. Which card/OS/system are you having trouble with? -- Basic Bob gbasigcbobg@gatt.gnet the g's are silent | |||||||||||||
Posted by Marc on June 2, 2005, 1:47 am
driver.
CPU.
And which card is that? Generally, the fastest cards do more work right on the NIC so there > is less for the CPU to do.
Same question. | |||||||||||||
Posted by $Bill on June 1, 2005, 8:54 pm
Marc wrote: >
driver.
>>Sure, if you are the designer, there are three things: chipset, firmware, and >>For the rest of us, the best you can do is pick a card which does not hog the
CPU.
> And which card is that? Don't know, but you should check the docs for each card and see what the description says. We had cards years ago that were called smart cards that did much of the TCP/IP work on the card (which had its own CPU and was downloaded with firmware on system startup). Today's CPUs are so fast that I wouldn't even bother paying the extra bucks for a smart card (we were running like 286's back in those days and it made sense at the time). I would think 3Com would have smart cards and you probably pay at least quadruple for them since a reg card is like $10-20. They'll offer remote management, processing offload features and the like. The NIC shouldn't be hogging the CPU unless you either have negligible CPU or extremely high network traffic. I would check both first. See what the CPU is like with the network disabled and see how much traffic you have with the net enabled and a monitoring tool checking the traffic load. You can get a little info from the Task Manager Networking tab (on XP and the like for example). I seldom go over 1% network utilization unless downloading which still stays under 10% since it's WB (not local LAN). | |||||||||||||
Wireless network card hogs cpu
Yahoo!
Windows Live
del.icio.us
digg
Netscape
