Cable Modems Ethernet cable not working, USB is working
Subject Author Date
Ethernet cable not working, USB is working Isurf 10-01-05
Posted by Isurf on October 1, 2005, 3:55 pm
I just got my Toshiba PCX2200 cable modem. I tried to connect using the
ethernet cable.
The cable modem lights for "Cable", "PC" and "Power" are on and "Data"
is flashing. However my laptop does not find a network. It is saying
that the cable is unplugged. I know I do not have problem with my
laptop nor the network card, since I am able to hookup to other
networks.
Using the USB cable I don't have a problem at all. I can connect.
I am thinking to buy a wireless router, but with this problem it may be
a waste of money since, I may not be able to connect through the
ethernet cable.
Please help.
Isurf
Posted by Eric on October 2, 2005, 7:14 am
Unplug the USB connection, plug in the Ethernet connection. Reset the
modem (unplug, count to 3, plug back in). When the modem registers
again, renew your IP address (should happen automagically with XP). If
this doesn't work, you may have a crossover cable (wire colors should
be the same on both ends of the cable when you hold the connectors side
by side), or a bad ethernet port.
Posted by Andrew Rossmann on October 2, 2005, 8:42 am
[This followup was posted to comp.dcom.modems.cable and a copy was sent
to the cited author.]
Isurf.1w8mae@news.broadbandbanter.com says...
> ethernet cable.
> networks.
Have you rebooted while the Ethernet cable is connected?
Have you tried, from a command prompt, doing an 'IPCONFIG /release',
followed by 'IPCONFIG /renew'?
If using XP, have you tried the REPAIR option in the left panel when
you click on the Ethernet connection in Control Panel/Network Settings?
If you directly connected to the cable modem, you cannot use a fixed
address. The network connection will need to be configured for DHCP
(Option xxxx automatically in the TCP/IP properties.)
If there is a no_junk in my address, please REMOVE it before replying!
All junk mail senders will be prosecuted to the fullest extent of the
law!!
http://home.att.net/~andyross
Posted by Quaoar on October 3, 2005, 9:15 am
> the ethernet cable.
> networks.
> be
> ethernet cable.
> Please help.
Power down the modem. While power to the modem is off, disable the USB
NIC, Enable the ethernet NIC. Shut down computer. Power up the modem,
then boot the computer. See if this helps. If not, Google for
winsockxpfix.exe to fix problems with layered services (assumes WinXP).
Q
Similar ThreadsPosted
Ethernet cable not working, USB is working October 1, 2005, 3:55 pm
internet network goes out, but cable modem and router seem to be working August 9, 2005, 10:59 pm
Netgear WGR614 router port 3 stopped working after cable installation November 27, 2004, 6:46 pm
My wi-fi not working with Adelphia!! August 1, 2006, 4:46 am
COX SMTP Just Stopped Working August 11, 2004, 12:07 pm
PING stops working January 17, 2006, 11:00 pm
Cable modem not working with TV cable plugged in November 2, 2006, 1:34 am
Switch stops working after five minutes - any switch I try. Please help. October 12, 2006, 6:24 am
Cable modem Ethernet and USB January 12, 2006, 5:47 pm
Can I get an IAD which contains 4-port ethernet switch + modem (cable or adsl)? March 22, 2005, 8:29 pm
USB to Ethernet Switchover September 14, 2007, 11:24 am
Tiscali ethernet modem settings ??? May 15, 2005, 9:14 pm
Tiscali ethernet modem settings ??? May 14, 2005, 11:13 pm
modem not talking to ethernet port April 13, 2005, 11:20 am
