Cable Modems Constant activity on router / cable modem - ARP???
Subject Author Date
Constant activity on router / cable modem - ARP??? retkaa 12-22-05
Posted by on December 22, 2005, 10:07 pm
Hello.
I've just moved to Canada from the UK, and this is my 1st cable modem
setup. I came home from work to find a nice Motorolo SurfBoard Cable
modem set up. I attached a new Netgear WGR614 to the modem, but having
done this a strange thing happens.
The internet activity light on the modem flashes continually, as does
the Netgear router internet activity light. This happens when no
devices are connected or even switched on! I am concerned about the
amount of bandwidth being used, and how to conserve it.
I read on a previous post something about ARP requests. What are ARP
requests, and why would they be causing constant web activity? Is
there a way to disable them (I have de-activated UPnP)?
Thanks in advance,
Rob
Posted by Gene S. Berkowitz on December 23, 2005, 1:19 am
retkaa@gmail.com says...
> Hello.
> Thanks in advance,
> Rob
ARP is Address Resolution Protocol. It is used by server to find out
and uniquely identify other machines on a network. ARP messages are
sent as an ethernet Broadcast message, which means that every machine on
that LAN segment will receive it. Since your neighborhood cable is
basically a LAN segment that could carry dozens or hundreds of clients,
there are a lot of ARP messages floating around.
They're harmless.
--Gene
Posted by on December 22, 2005, 11:11 pm
OK, thanks for the reply. But how come the internet activity light
stops on the cable modem when I unplug the router? It only flashes
like crazy when the router is connected.
Rob
Posted by Gene S. Berkowitz on December 23, 2005, 2:17 am
> Rob
Because until the router is connected, the modem has nothing to forward
the ARP requests to...
--Gene
Posted by Fafa Fofo on December 23, 2005, 8:40 am
I've seen the same thing on some of Comcrap's setups. They have some
system(s) pumping out constant ARP (Address Resolution Protocol)
messages to potential messages. For example, you'll see 216.100.100.1,
216.100.100.2... Frankly, I think that they're looking for invalid
connected systems. Even though your router should be set to ignore
ping requests, it will always respond to ARPs. I complained about it
to Comcrap and they simply denied that the messages exist.
On 22 Dec 2005 22:07:23 -0800, retkaa@gmail.com wrote:
>Hello.
>Thanks in advance,
>Rob
Similar ThreadsPosted
Constant activity on router / cable modem - ARP??? December 22, 2005, 10:07 pm
SB3100 modem Linksys BEFSR81 Router/switch- high activity January 28, 2005, 1:35 am
Cable Modem Activity August 9, 2007, 10:47 pm
Re: Question on identifying cable-modem activity December 13, 2007, 1:56 pm
Re: Question on identifying cable-modem activity December 13, 2007, 3:45 pm
video noise during internet activity September 24, 2004, 6:51 am
How do you solve unknown data activity. March 16, 2005, 10:17 pm
cable modem - router - help January 7, 2005, 2:33 am
combo cable modem + router/NAT August 31, 2004, 2:15 pm
cisco router to NTL Cable Modem October 15, 2006, 7:24 am
Best Cable Modem Wireless Router Unit? March 2, 2005, 9:06 pm
Cable modem, Router, Desktop and now Laptop June 12, 2005, 12:04 am
wireless router cable modem recommendations? July 30, 2005, 11:59 pm
router connect to cable modem (need login or not?) June 18, 2006, 10:16 pm
Can I get a Cable Modem + 4-port Switch-cum-Router in one single Box??? January 4, 2005, 1:51 pm
