Cable Modems Comcast and MAC addresses?
Subject Author Date
Comcast and MAC addresses? Edward 11-03-06
Posted by Edward on November 3, 2006, 12:29 am
Does comcast bind the MAC address to the first thing it sees when the
service is snabled? I bought a new router and I had to clone the MAC
addy from the NIC I first used two years ago.
Is that normal, or is it just a cooincidence?
Posted by Bill M. on November 3, 2006, 12:34 am
It's normal if you forgot to power cycle your cable modem.
Bill
Posted by Edward on November 3, 2006, 12:39 am
> Bill
I tried that, and still couldn't get an IP.
Posted by Bill M. on November 3, 2006, 1:29 am
>> Bill
Ok, second try.
>> >service is snabled?
No, but the modem binds to the first MAC address it sees after a
reboot.
No, you didn't have to.
It's not normal. What should happen is that you've turned off the
modem, old router, and PC. You swap out the old router for the new
one. You turn on the modem and wait for it to stabilize. You turn on
the new router and wait for it to stabilize. You turn on the PC and
you're ready to go. I can't tell from your description if you've
skipped any of those steps.
On the other hand, cloning your old MAC isn't such a bad thing,
either, as long as the old NIC that it really belongs to is not being
used anymore. Is there a reason why you want to avoid cloning?
Posted by Edward on November 3, 2006, 7:26 am
> >> Bill
> Ok, second try.
> >> >service is snabled?
> reboot.
That's exactly what I did.
Its just luck that I strill have this board with this particular NIC in
it. If I didn't have it anymore I would be shit outa luck.
Similar ThreadsPosted
Comcast and MAC addresses? November 3, 2006, 12:29 am
Private IP addresses Cablevision September 8, 2004, 10:27 pm
Netgear reserved addresses June 22, 2005, 2:04 pm
Connect via wireless router and ip addresses June 8, 2005, 12:50 am
2 Public IP Addresses on 1 Cable Modem March 16, 2006, 1:47 pm
NEW TOOL: SMAC-CL 1.0, Console App for modifying MAC addresses July 14, 2004, 3:40 am
Re: IMPORTANT!! ALL COMCAST Subscribers!! PLZ READ! COMCAST COMCAST November 1, 2006, 11:36 am
Re: IMPORTANT!! ALL COMCAST Subscribers!! PLZ READ! COMCAST COMCAST November 6, 2006, 2:04 pm
Comcast November 15, 2005, 10:33 pm
What is it with Comcast DNS September 17, 2006, 4:46 pm
What up with Comcast DNS? October 26, 2006, 2:54 pm
Comcast MTU August 27, 2007, 10:16 pm
comcast in chicago August 8, 2004, 3:04 pm
Comcast self-install kit - do I need to buy it? August 17, 2004, 4:07 am
Best version of XP for Comcast August 22, 2004, 8:30 pm
