Cable Modems Best cable modem setup?
Subject Author Date
Best cable modem setup? Dennis K. 01-11-07
Posted by Dennis K. on January 11, 2007, 2:40 pm
Adelphia (now TimeWarner) is coming out tomorrow to install RoadRunner.
I have several PCs connected on an ethernet via a hub. The PC I want to
be the host for the cable internet connection only has a low-speed USB
port.
Would it be best to install the cable modem on the PC's USB port or on
the ethernet hub?
Dennis K.
Posted by Bill M. on January 11, 2007, 8:23 pm
>port.
>the ethernet hub?
I wouldn't bother making one of the PC's the host. What most people do
is connect a router to the cable modem, then the individual PC's get
connected to the router via its built-in switch. No host, no hub, and
definitely no USB. Put an Ethernet NIC into each PC that doesn't
already have one.
Bill
Posted by Warren on January 11, 2007, 8:57 pm
> port.
> the ethernet hub?
Neither.
Go out, and get a router. You can replace the hub with the router, or just
connect the hub to the router.
Networking using USB connections is awkward at best. It should only be
used if a bus designed for networking (most commonly Ethernet) is not
available. And if your network uses a hub or a switch, and the PC is not
functioning as a router, you would need to pay for multiple IP addresses
to address everything on your network.
If you really want to emulate Rube Goldberg, have fun. But the easy way is
to just get a router, and make it easy on yourself.
Warren H.
Disclaimer: My views reflect those of myself, and not my
employer, my friends, nor (as she often tells me) my wife.
Any resemblance to the views of anybody living or dead is
coincidental. No animals were hurt in the writing of this
response -- unless you count my dog who desperately wants
to go outside now.
Shop for networking gear:
http://www.holzemville.com/mall/linksys
http://www.holzemville.com/mall/netgear
Posted by Todd H. on January 11, 2007, 10:17 pm
> > port.
> > the ethernet hub?
> Neither.
Hands down agreed. Replace the hub with a linksys BEFSR41 or WRT54G
(wireless) or equivalent. Both are reasonably priced and relatively
ubiquitous.
Best Regards,
Todd H.
http://www.toddh.net/
Posted by Dennis K. on January 12, 2007, 10:29 am
>ubiquitous.
I am reading up on the linksys BEFSR41. It talks about a web based
setup. If all I have right now is dial-up, can it still be setup? Or do
you need to connect it the high-speed cable to set it up? In other
words, what should I get installed first ... the router or the
high-speed cable. Chicken or egg?
Dennis K.
Similar ThreadsPosted
Best cable modem setup? January 11, 2007, 2:40 pm
lan setup help using cable modem as bridge September 13, 2005, 5:21 pm
cisco 1721 to cable modem setup August 12, 2006, 1:52 pm
Wireless Setup July 14, 2004, 7:10 am
Need help with network setup June 2, 2005, 4:13 pm
setup of a transparent gsm data call using V.32 July 14, 2004, 12:41 pm
BEFSR41 Linksys Router & VPN Setup October 26, 2004, 11:40 pm
How to setup Agent for Charter.net thru my work Bellsouth dsl isp? October 31, 2005, 8:00 pm
Hub/Router setup question for RoadRunner in upstate New York January 4, 2005, 2:57 pm
Using Cable Modem and DSL Modem at the same time November 10, 2004, 12:47 am
Cable modem not working with TV cable plugged in November 2, 2006, 1:34 am
My cable modem is down August 15, 2004, 2:08 pm
Re: My cable modem is down August 28, 2004, 7:31 am
Do I need a new cable modem? February 15, 2005, 3:00 pm
what cable modem to ge March 30, 2005, 10:15 am
