Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Persephone on September 28, 2005, 10:13 pm
Please log in for more thread options Hello: I am getting ready to try again, my old Adelphia Powerlink ISP and see if MAYBE things MIGHT be different..... The last time I had it, it kept disconnecting and I live in an apartment complex that was built in 1967, the wires can be accessed that run INTO my apartment and at the main line on the outside pole. I was told by the last Tech I had hear, and I had SEVERAL here, that said the reason my connection kept failing was that the wires that they NEEDED to get to was inaccessible cause they are behind walls in the building, of course, the management is NOT going to let them tear any walls out, so, my question is this.... Is this true/applicable and is there a workaround like a booster or some other device? Thanks!! Mary Beth | |||||||||||||
Posted by $Bill on September 28, 2005, 7:29 pm
Please log in for more thread options Persephone wrote: Your best bet would probably be to have someone test the cabling *to* your apt and also *inside* your apt for signal loss with their test equipment and if it isn't up to snuff, pull new RG6 wiring through to replace the old. Shouldn't require any damage to your walls to pull new wiring through. You may have to pay for it though depending on your cable ISP and apt rules. | |||||||||||||
Posted by Persephone on September 28, 2005, 10:57 pm
Thanks!!!!! I saved your response and I'll tell my Adelphia people about it.... > Persephone wrote:
> > Hello:
if
> > > > I am getting ready to try again, my old Adelphia Powerlink ISP and see > > MAYBE things MIGHT be different.....
my
> > > > The last time I had it, it kept disconnecting and I live in an apartment > > complex that was built in 1967, the wires can be accessed that run INTO > > apartment and at the main line on the outside pole.
said
> > > > I was told by the last Tech I had hear, and I had SEVERAL here, that > > the reason my connection kept failing was that the wires that they
NEEDED to
my
> > course, the management is NOT going to let them tear any walls out, so, > > question is this....
> > > > Is this true/applicable and is there a workaround like a booster or some > > other device? >
> Your best bet would probably be to have someone test the cabling *to* > your apt and also *inside* your apt for signal loss with their test > equipment and if it isn't up to snuff, pull new RG6 wiring through to > replace the old. > > Shouldn't require any damage to your walls to pull new wiring through. > You may have to pay for it though depending on your cable ISP and apt > rules. | |||||||||||||
Posted by James Knott on September 29, 2005, 8:14 am
Persephone wrote: > Is this true/applicable and is there a workaround like a booster or some
> other device? If there's a problem with the cable, a "booster" will likely not help much. However, the problems are more likely to be in a connector. That said, cables do have a usable lifespan, and should be replaced occasionally. In apartment buildings the usual practice is to run new cables on the outside of the building. BTW, why do so many people not know the difference between "lose" and "loose"? Unless the cables are too tight, the word you want is "losing" | |||||||||||||
Posted by Persephone on September 29, 2005, 11:28 am
Opps...I even noticed that I spelled Powerlink wrong...AFTER I hit the SEND button...... )-: I will inform my Cable co. of these issues concerning lost connects BEFORE the do an install..... Thanks!! Persy.... > Persephone wrote:
> > other device? >
much.
> If there's a problem with the cable, a "booster" will likely not help > However, the problems are more likely to be in a connector. That said,
> cables do have a usable lifespan, and should be replaced occasionally. In > apartment buildings the usual practice is to run new cables on the outside > of the building. > > > > BTW, why do so many people not know the difference between "lose" and > "loose"? Unless the cables are too tight, the word you want is "losing" | |||||||||||||
| Similar Threads | Posted |
| Adelphia Powerlingk and loosing connections... | September 28, 2005, 10:13 pm |
| Modem to Modem Connections | December 23, 2004, 10:53 pm |
| New ADELPHIA User | April 19, 2005, 1:52 am |
| I have adelphia internet | July 23, 2006, 11:04 am |
| My wi-fi not working with Adelphia!! | August 1, 2006, 4:46 am |
| Adelphia cable modem | June 1, 2005, 2:20 pm |
| Does Adelphia block ports? | November 24, 2005, 12:17 am |
| Linksys Router - No IP Address from Adelphia | July 10, 2005, 8:50 am |
| signal strenght problem with adelphia? | October 13, 2004, 2:29 pm |
| Problems with adelphia cable modem service | December 7, 2004, 1:35 pm |
| Cisco ubr924, how to disable IOS updates from Adelphia | July 21, 2005, 3:26 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> other device?
