After bouncing around RoadRunner Nat'l Help Desk for almost an hour, I finally got to speak with the California Tier 3 Help Desk in Colorado(!).
After about 40 minutes of doing various tests and tracerts, and a cute test at
Problem 1
The software that checks billing accounts to see what speeds you're entitled to is screwed up so that the wrong parameters are downloaded to your modem's bootup file. No matter how many times the tech rep tries to correct your modem's parameters, the billing account-checking software will override it and not allow you to get the level of speed you're entitled to.
Problem 2
No matter how much speed you get as measured from TimeWarner's speed website
Both these problems are systemic and not a problem with your PC or cable modem, and the Colorado Tier 3 techs have notified both the Network Ops Center and the billing software departments about these problems. But who knows how long it will to get them fixed. I'll wait until January 1. After that, I'm off to DSLextreme if nothing improves.
*TimDaniels*
