I just received a Zwave 300W dimmer and am trying to wire it up. The Zwave switch has four wires - black, white, red, and green.
I am replacing a two wire switch which controlled four hi-hat lamps each with a 75 watt bulb in them equalling 300watts, equalled to the dimmer's rating.
My question is where does the RED wire connect to? The diagram says black to black...white to white which goes to a circle called load...and Red directly to load. Does that mean the red and white go togehter?
If so, I tried that and when I turned on the dimmer, the lights were flickering rapidly.
If I left the Red wire out completely, the lights did not turn on at all.
Any ideas?
