Hello,
I am building a retaining wall and a 2 tier garden system, within the retaining wall I will be istalling 240V Brick lighth approx 22 lights in total connected to 3 different X10 Relay Receiver (DIN Mounted) AD10, these DIN devices will be installed into a IP-66 rated weather proof distribution board that will be connected to my mains box.
I do have a problem thought I have to run underground conduit under a pathway, the local rules require a minimum depth for the conduit of 50cm and I am in the process of digging the trenches at the moment. Is there any suggestions from the gurus out there of how to get underneath the path without breaking it ? I was thinking of using a metal tube or a wooden steak to hollow out the ground but if there is an easier way I would love to hear it.
Thanks for that help Imran
