I need to set up a switch to control outdoor lighting of a long driveway - up to 200 ft. The lighting system is 12 vdc and it is controlled by a switch at one end of the driveway, only. I'd like to be able to switch it on/off from both ends.
If I were to change the switch to an x10 (or similar) device with remote capability, will the remote have sufficient range to switch the system on/off from a distance of up to 200 ft? What is the practical limit on range of the remote unit? Is the range diminished by cold (the switch will be located in an unheated garage
- winters can easily be - 30C)? Finally, is the unit strictly line-of-site or RF?
Thanks
__________________________________________ Mark Turner ©¿© Toronto, Ontario Canada __________________________________________
