Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Lacustral on August 18, 2007, 1:34 pm
Please log in for more thread options I'm looking for a delay switch for a bathroom fan and I haven't found any that have exactly what I want - - adjustable time interval from a few minutes to, say, 1/2 hour. I'd rather not get one that just has a few choices for time interval. You can get one that gives you 5,10,15, 30 or on-until-switched-off choices, but I'd like to have it completely adjustable. - time delay interval controllable on the outside of the faceplate - doesn't make noise. Spring timers all click as I've heard, so not a spring timr. What the delay switch does, is you can leave the fan on after you leave the bathroom, for an adjustable time. The closest thing I've found is this: http://www.rewci.com/fandetisw.html It has a delay of up to an hour. I don't know why anybody would want to keep the fan on in the bathroom for an entire hour after leaving, but I guess it's conceivable. So I'd live with that. But it's designed so the time delay adjustment is hidden behind the faceplate, and changed with a screwdriver. I want to have the delay adjustment on top of the faceplate. So there would be a sort of screwdriver blade attached to a knob, anchored to the faceplate somehow. Any ideas about how to do this, so it would work reliably? Alternatively, I'm sure it's possible to get a circuit that will do the delay function. If the guts of it could be covered over so it looks nice - I could buy a wood faceplate and cut circular holes in it for the knobs - that would also do. It would have to fit in a gang box, or whatever they call the metal box that switches are enclosed in. Laura | ||||||||||||||||
Posted by Farticus on August 25, 2007, 9:26 pm
Please log in for more thread options ... perhaps a VERY big smell? | ||||||||||||||||
Posted by ctyguy on August 27, 2007, 5:18 am
>> The closest thing I've found is this: >> http://www.rewci.com/fandetisw.html >> >> It has a delay of up to an hour. I don't know why anybody would want to >> keep the fan on in the bathroom for an entire hour after leaving, >
> ... perhaps a VERY big smell? > Bathroom fan should be continuous, like the fan on a CPU. NBD Since the time man has done his business in the space where he lives, the stench will not leave w/o 24/7 exhaust. | ||||||||||||||||
Posted by Dave M on September 5, 2007, 1:25 pm
>that have exactly what I want - >- adjustable time interval from a few minutes to, say, 1/2 hour. I'd >rather not get one that just has a few choices for time interval. You can >get one that gives you 5,10,15, 30 or on-until-switched-off choices, but >I'd like to have it completely adjustable. >- time delay interval controllable on the outside of the faceplate >- doesn't make noise. Spring timers all click as I've heard, so not a > spring timr. > >What the delay switch does, is you can leave the fan on after you leave >the bathroom, for an adjustable time. > >The closest thing I've found is this: >http://www.rewci.com/fandetisw.html > >It has a delay of up to an hour. I don't know why anybody would want to >keep the fan on in the bathroom for an entire hour after leaving, but I >guess it's conceivable. So I'd live with that. > >But it's designed so the time delay adjustment is hidden behind >the faceplate, and changed with a screwdriver. I want to have the delay >adjustment on top of the faceplate. So there would be a sort of >screwdriver blade attached to a knob, anchored to the faceplate somehow. > >Any ideas about how to do this, so it would work reliably? > >Alternatively, I'm sure it's possible to get a circuit that will do the >delay function. If the guts of it could be covered over so it looks nice >- I could buy a wood faceplate and cut circular holes in it for the >knobs - that would >also do. It would have to fit in a gang box, or whatever they call the >metal box that switches are enclosed in. > >Laura Perhaps one of these timers might suit your purpose. Might take a bit of mechanical work to install but shouldn't be too hard. http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=11333 http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=12340 http://www.sciplus.com/singleItem.cfm?terms=12231&cartLogFrom=Search http://www.surpluscenter.com/item.asp?UID=2007090512144066&item=1-1614&catname= Cheers!!!! ============== Dave M Never take a laxative and a sleeping pill at the same time!! | ||||||||||||||||
| Similar Threads | Posted |
| time delay switch | August 18, 2007, 1:34 pm |
| Effect of upcoming changes to Daylight Savings Time | January 11, 2007, 3:44 pm |
| 360 degree real-time panoramic video...Interested? | April 21, 2007, 12:15 pm |
| RF light switch | September 15, 2005, 2:33 am |
| gate switch | December 10, 2005, 10:59 pm |
| X-10 Switch Question | April 14, 2008, 10:11 pm |
| X10 switch control logic | February 16, 2005, 11:32 am |
| Beggginer 3-way switch question.... | September 22, 2005, 5:33 pm |
| 3-way motion sensor switch | February 8, 2007, 11:36 am |
| Is special X10 slave required for 3-way switch? | November 10, 2004, 10:49 am |
| UPB dimmer switch (must be light almond) | August 7, 2005, 12:34 am |
| remote controlled light switch | January 29, 2006, 1:41 pm |
| 3-wire Garage door switch | August 26, 2007, 8:37 pm |
| oil fired furnace X-10 off/on switch control | April 18, 2008, 1:41 pm |
| Is special X10 companion switch required for 3/4-way X10 circuits | November 18, 2004, 9:42 am |
time delay switch
Yahoo!
Windows Live
del.icio.us
digg
Netscape
