Suddenly Dead MC460?
Threaded View
This unit is perhaps a little over 2 years of age. It has worked just
fine for that entire period. However, today it seems to have stopped
working all together. When I press any on/off rocker button, I see the
little red light blink. But nothing happens on any X-10 device in the
house. I have moved it to several other outlets to test with the same
results. Other units of the same or similar model work fine. Is this
thing trash or is there some common issue that I might be able to fix?
Thanks.
Re: Suddenly Dead MC460?
On Sun, 3 Oct 2010 01:11:54 +0000 (UTC), David White
Other than exercising both the house code selector dial and the device number
slider switch to ensure those are both making good contact in their correct
settings, I can't think of anything else worth trying. You can get an MC10A
replacement for $11 including shipping on Ebay. http://tinyurl.com/32sngbe
Tony
Thanks Tony. Did what you suggested to test. No changes. So I plan to do
your other suggestion (EBay) today.
Site Timeline
