Smart Glass
Threaded View
I am trying to source some electrical contacts in a run of 6 folding
sliding doors in order to pass the electrical current for some smart
glass.  I envisage that they may be a plunger type similar to some car
door contacts.
Hope someone can help me source them
Re: Smart Glass
"macawood" wrote:
I suspect you'll have better luck using wired hinges.  These are commonly used
to connect electronic door locks but they can be used for purposes such as
yours.  I work with several manufacturers of locksmith supplies and access
control systems.  If you can give me the specs for the hinges on your doors
I'll suggest an appropriate model.
Regards,
Robert L Bass
Bass Home Electronics
DIY Alarm and Home Automation Store
http://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-870-2310
Fax 941-870-3252
Site Timeline
