reset modem
Threaded View
hello
my broadband modem forgets what it doing every couple of days and it needs
the power disconnecting for 10 seconds to remind it.
i would like to be able to do this automatically when a program i've written
recognises that the net is off-line.
what is the best way to achieve this?
Re: reset modem
If you've already written the program to determine if you're
connected, you can purchase an X10 kit (transceiver, firecracker
module for your serial port, and an appliance module to control your
modem's power source.  Install bottlerocket (for Linux), or some other
automatable program to control the firecracker, and when your program
detects the outage, send a signal to turn off the modem, then turn it
back on!
Moshe [TMTOWTDI!]
*** SPAM BLOCK: Remove bra before replying! ***
http://runslinux.net :: moshe at runslinux dot net :: AIM: Jehsom
Re: reset modem
http://www.homeseer.com/downloads/index.htm
If your program is in windows you can find some activex controls to work
with different x-10 devices, free.
Site Timeline
