Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Snydley on January 29, 2006, 1:41 pm
Please log in for more thread options I want to control my garage's outside light from inside my house with a remote controlled RF light switch. The light is currently controlled with 2 - 3 way switches, one on both floors of the garage. The light was never wired to the house, and the only way to control it now is to walk out to the garage and turn it on or off. I'd like to be able to do this remotely from the house. Does anyone manufacture some kind of receiver/switch and remote control that you can wire into an existing 3 way circuit? Has anyone here ever done this? I appreciate any help you might bring. Thanks, Snyde | ||||||||||||||||
Posted by Brian on January 30, 2006, 8:00 am
Please log in for more thread options Yes for RF look at Zwave, -- --------------------------------------- Brian Dye brian@tech-home.com http://tech-home.com --------------------------------------- | ||||||||||||||||
Posted by Charles Sullivan on January 30, 2006, 5:24 pm
On Sun, 29 Jan 2006 18:41:19 +0000, Snydley wrote: > I want to control my garage's outside light from inside my house with a
> remote controlled RF light switch. The light is currently controlled with > 2 - 3 way switches, one on both floors of the garage. The light was never > wired to the house, and the only way to control it now is to walk out to the > garage and turn it on or off. I'd like to be able to do this remotely from > the house. > Does anyone manufacture some kind of receiver/switch and remote control that > you can wire into an existing 3 way circuit? > Has anyone here ever done this? I appreciate any help you might bring. > Thanks, > Snyde I'm assuming that although a garage light switch was never wired to the house, the garage is powered from the same breaker box as the house. I have an X10 system at my house which started out simply with the same requirement as yours, but which has now been expanded to control over 20 lights in various remote locations. You could use the following set of X10 components from <http://www.x10.com/catalog/cat_automation.htm>
WS4777 or WS12A 3-way Wall Switch module (includes master + slave) TM751 RF Transceiver SS13A or SS15A Slimline Wireless Wall Switch (or any other x10 RF transmitter) Or you could use a plug-in X10 Controller like the MC460 Mini-Controller along with the 3-way wall switch module and forget the RF transmitter and transceiver. (Basic X10 operates by sending control signals over the AC power lines.) | ||||||||||||||||
| Similar Threads | Posted |
| remote controlled light switch | January 29, 2006, 1:41 pm |
| key fob controlled light | October 10, 2005, 9:06 am |
| Porch light by remote question. | May 2, 2005, 1:34 am |
| RF light switch | September 15, 2005, 2:33 am |
| UPB dimmer switch (must be light almond) | August 7, 2005, 12:34 am |
| Singing light bulb on dimmer switch | May 20, 2006, 3:22 am |
| one switch operated 6 seperate light areas, who makes this? | August 22, 2005, 11:06 am |
| x-10 and radio controlled devices | December 2, 2004, 8:25 pm |
| Computer-Controlled Power Outlet | June 8, 2006, 5:09 pm |
| x-10 and remote control | December 29, 2004, 1:01 pm |
| x10 remote range | August 25, 2005, 1:11 am |
| how to buiild a Powermid Remote Sender | November 10, 2004, 3:17 am |
| mobile phone remote control | December 16, 2005, 9:16 am |
| Question on Remote Data Access | January 2, 2007, 12:59 pm |
| Garage Door Opener Remote Question ? | July 21, 2005, 5:21 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> the
> the house.
> that
> Thanks,
> Snyde
