Hi all,
We have an old mechanical Intermatic T107-30 timer which controls our landscape lighting. In the last few weeks, the timer started acting up - it is running extremely slow.
Basically for every hour, the timer will only run ~2 minutes.
Is it worth getting this timer repaired? Does anyone know if there is a simple fix for this issue?
If not, can anyone recommend a timer which will:
- Control ~1000 - 1500W of lamps
- Sunset programming AND turn off the lamps at a fixed time (i.e. 3:00am).
- Multiple programs (turn on at sunset and turn on around 5:00am?).
Since this is for residential use... something cheap + reliable would be ideal ;-)
Thanks!
