Home Automation nightlight solution needed
Subject Author Date
nightlight solution needed Clyde 04-20-05
Posted by Clyde on April 20, 2005, 12:57 pm
I need a custom home lighting controller for my disabled father. What
I want it to do is control track lighting that will be used like a
nightlight. The operation is this:
When the circuit is triggered (either by a pressure mat by the bed or
an IR device to sense when my father has gotten out of bed) it will
turn the track lights on. The lights will stay on until my father
gets back into bed and then pushes a bedside switch to turn the lights
off. If my father gets back out of bed the circuit will trigger
again.
Posted by Brett Griffin on June 17, 2005, 3:22 am
For elederly application you will want to consider a complete home
automation system. This is not overly expensive. I would recommend using
an HAI Omni LT (www.homeauto.com) with some motion sensors, and a floor pad
like you mention. If you or someone you know is familiar with electrical
you could do this for under $1000. And have a decent system, with a lot of
capabilities to monitor you father.
Brett Griffin, Technology Consultant
Architechtronics, Inc.
get to know home technologyT
p. (610) 825.7018 f (215) 827.5484
*top 10 reasons to use Architechtronics for your next project
http://www.architechtronics.com/top10.html
**keep up on cutting-edge technology... join "the EDGE" for free at
http://www.architectronics.com/edge.html
> again.
Similar ThreadsPosted
nightlight solution needed April 20, 2005, 12:57 pm
2 100 amp panel coupler help needed December 11, 2005, 9:08 pm
Help needed with Sockets, using Mister House... September 15, 2005, 10:15 pm
Dial-up home automation assistance needed June 10, 2006, 1:39 am
Brake method needed for hillside lift October 28, 2006, 3:46 pm
Recommendation needed: Monitor vacation home, detect outages August 21, 2005, 8:25 pm
