Home Automation newbee Q: X10 experience ?
Subject Author Date
newbee Q: X10 experience ? Freaking Media 02-14-05
Posted by Freaking Media on February 14, 2005, 11:07 pm
Does anyone have practical experience with the X10 home automation modules.
They seem OK but I heared rumours like the X10-system isn't reliable ?
flxy
Posted by Brian on February 15, 2005, 1:13 am
X10 can be realiable but may take some work to get it this way. Noise on the
powerline can cause alot of problems. If you go with X10 buy quaility
products, a coupler/repeater, a few filters, and a signal tester can be a
great asset. Some have great luck with X10 others just get frustrated. It
can take some time trouble shooting issues. For me this was too much to get
a system working so I installed Zwave, a RF solution.
Brian Dye
brian@tech-home.com
http://tech-home.com
> modules.
> flxy
Posted by Freaking Media on February 15, 2005, 10:30 pm
> It depends what you mean by reliability. I have about 25
> X10 modules controlling household and landscape lighting
> via a CM11A computer interface. It's been operating for
> about 7-8 years. In that time I've only very rarely had
> a light fail to turn on or off at its programmed time.
> I had one wall-switch module go bad for the first time
> last year. (Note: my wall-switch modules are only rarely
> operated manually - that is an apparent weak spot in the
> design of the X10-manufactured units.)
> However there are a number of factors whereby other users
> could have a very different experience from mine.
> I would never use X10 in any situation where personal injury,
> damage to property, or substantial financial loss would
> result from failure of the X10 system to perform as expected.
Thanks,
are there more reliable alternatives ?
Flxy
Posted by Markus Baertschi on February 15, 2005, 11:07 pm
Freaking Media wrote:
> Thanks,
> Flxy
There are the professional, hardwired solutions. Very reliable, but
quite expensive, especially if you want to start small and do it yourself.
Some new RF technologies are starting to come up, but the product line
are still very limited.
Markus
Posted by Brian on February 16, 2005, 6:45 am
Just a few
Zwave (RF)
UPB (Powerline but better technology)
Zigbee(Soon) RF
SMarthome is about to introduce a RF & powerline mix (Insteon)
Several hardwire options they are the best if you have acess to running the
wires
Lightolier (has plc and hardwire options) Very realiable
Lutron
Several others but just wanted to throw a few out.
Brian Dye
brian@tech-home.com
> Thanks,
> Flxy
Similar ThreadsPosted
newbee Q: X10 experience ? February 14, 2005, 11:07 pm
newbee: HAL February 16, 2005, 2:32 pm
any one have any experience with this new product? August 19, 2005, 1:27 pm
