Need UPB Set up help
Threaded View
 am building a home and need some expert adice from you folks out
there.  Thinking of going UPB or should I go x10.  I've got UPB
deveices specified below, if you think I should go x10, please let me
know the devices I need to buy.
Q1 - If I need to control only 1 light or series of lights connect to 1
switch do I just get a Master Dimmer (SAUS1130A) or would any Salve
dimmer (SAUSR1) work
Q2.  If I have a few lights controlled by 2 swicches doe I need 1
master and 1 slave?
q3.  What kind of switch do I need to control a fan?
q4.  What kind of switch do you recommend for a fluorescent light.
Which products do you recommend I buy.  I've found the following UPB
devices, will they work on my home?  Are there better products I can
use and do I need all of the following below?
Phase Coupler -  Simply Automated -  Universsal Phase Coupler -
SA-ZPCB
Computer Interface - Simply Automated - UPB Computer Interface Module -
SA-UMCDB9W
Single Dimmer \\ Master - Simply Automated- Single UPB Dimmer Switch -
SAUS1130A
Single Dimmer \\ Slave Switch - Simply Automated - UPB Companion Dimmer
Switch
 SAUSR1A
Surge Protector - Leviton -  LEVITON WHOLE-HOUSE SURGE PROTECTOR -
51120-1
I need to Control:
a. 25 Light switches, of which 3 rooms have additonal switches
controlling the same lights
b 7 wall outlets
c.2 fluorescent lights
d. 3 fans
What is the best way to program these switches: Which Omni product
should I go with.
Would appricate any help you guys could give
master and 1 slave?
SA-ZPCB
SA-UMCDB9W
SAUS1130A
Switch
 SAUSR1A
51120-1
I need to Control:
b 7 wall outlets
d. 3 fans
should I go with.
Re: Need UPB Set up help
A master, a slave is for a 3-way switch.
Yes as stated above.
Setup as a relay not dimmer
Relay like above.
I prefer Elk products and they support UPB. But I also sell HAI OMNI.
You program them with SA upstart.
http://www.simply-automated.com/products/sa_upstart.htm
And if you want I should be able to get you a great package deal. Just email
me a detailed list. The great thing about SA switches is Every switch is a
dimmer, a relay switch AND a transmitter depending on how you program it.
Brian Dye
brian@tech-home.com
http://tech-home.com
Site Timeline
