Hi all,
I've an X10 mouseremote with receiver and it works reasonably well. This jr20a remote passes some of the 'modes' to the jr21a receiver while others are only sent locally. PC, DVD, CD, Web are all sent as RF and the others get sent only as IR. This works fine.
I was surprised to also see the jr21a receiver also listens to the ur47a remotes. But the RF codes it sends are somewhat different than what the jr20a mouseremote sends. Most notably there appears to be only one 'mode', using the AUX key.
I think the mode buttons on the jr20a are basically just toggles, the don't actually change the format of the codes being sent. I think they're just used within the receiving program to indicate 'which mode' subsequent commands should be applied toward. What was odd was seeing the jr21a receiver see the cursor arrow keys on the ur47a as mode changes.
So I'm asking several things here.
Since the jr21a senses ur47a (dvd remote) signals, what would the mr26a sense from the jr20a (mouseremote)?
What, if any, 'remote' codes does the mr26a pass to girder?
What can a firecracker send in this regard? Can it send RF signals the mr26a would see as coming from a remote?
Thanks,
-Bill Kearney
