Low-Voltage Lighting Recommendations, Please
Threaded View
I am looking for sources of inexpensive 12V lighting to be used to
illuminate shelves.
I believe that halogen bulbs are used, usually in small round cases.
I would like to use two lights on a single transformer on each of four
shelves.
Thanks,
Eric
P.S. Sorry about posting to two groups - my lame newsreader doesn't
understand cross-posting.
Re: Low-Voltage Lighting Recommendations, Please
Have you considered using LED lighting?  White LEDs will give good shelving
and display lighting and consume very little electricity.  Do a google
search for 'LED lighting' and you will get lots of information.
Kale,
Thanks for the suggestion - I'll check it out.
Regards,
Eric
Glad I could help.  There's a lot of different LED fixtures out there now
that are direct drop-in replacements for regular lighting, and there are
also a lot of 12V systems as well.
Kale
Site Timeline
