This SMD Oven Controller (SMDOC-01) is designed to use with a toaster oven. The temperature profile is similar to the expensive industrial SMD oven provided. So, the sample quality is as good as the industrial oven can do. It is capable for packages including 0402, BGA, QFP, SOP, SSOP, TSSOP, SOT, etc. It is an indispensable tool for R&D and making samples. It is very suitable for electronic companies, laboratories, universities and hobbyists. SMD Oven Controller (SMDOC-01) is only US$206, including oven (PCB size is large up to 19 x 17cm) is US$283. Voltage 220V, 8A fused.
Features:
1.Small, low price, performance comparable to expensive industrial SMD oven. 2.Capable for any SMD packages. An indispensable tool for R&D, sample making and small batch production. 3.No hand soldering. No painful. No difficult. Save time. 4.Connectable to PC via RS232 for profile setup and temperature monitor. It can also operate independently without PC. 5.Simple to use. LEDs indication for each stage of pre-heat, soak, reflow and cooling. Alarm and power cut off after finished.Product information :
