Irda control a sound amp
Im trying to control a amp by IrDA ,I have a SigmaTel USB Dongle. I have tryed Remocon-Con Ver.2.8 but keep getting the error (The system dll user32.dll was relocated in memory ,....memery occupied an address reserved for windows).
Is there any windows software that I can use to do this, if possible something that would learn from the real remote.
I will tell you what I have here : A headless unit running 2k that is used as a mp3 store for winamp and I remote access this from a laptop by UlraVNC.
So what I need is to be-able to control the amps from the laptop aswell.
The laptop runs XP Home.
I hope that that is understanable.
WW
WeeWillyTonka
Which won't work. IrDA operates at different frequencies that most AV remotes. Most IrDA dongles cannot send the sort of signals needed. *Some* can but often not very reliably.
I use a USB-UIRT for IR signals and NetRemote for software control, works great.
wkearney99
