Have just learned that a house recently moved into apparently has no gas shut off valves located inside the house for the gas dryer, or the gas kitchen stove.
There is one for the furnace and hot water heater.
Plumber says it would be a really good idea to install one for the stove and dryer, and, of course, it would be.
But was wondering how "necessary" this is. The expense of a few hundred dollars is a bit of a concern.
Is this a "must-do" kind of thing ?
Are many houses in this situation, where the mains shut off valve outside the house is the one that would have to be used in an emergency, or whatever ?
Also,
This is the first time with a house with gas for the dryer and stove. Was a bit surprised to see that these appliances are plumbed in pretty rigidly to the gas pipe. Would have thought a flexible hose would have been used for the last few feet or so to allow some positioning or movement of the appliance. But, I guess not.
Anyone care to explain this a bit ?
Thanks.
