3
- Vote on answer
- posted
13 years ago
3
This link shows it for around $130.00
My spring broke and the opener (1/2 HP) lifted it just fine. They are not designed for this load everyday, for sure.
This was a garbage board / solid wood type door but only single size = 7 x
8'. The opener was a Genie screw mechanism type. Any 1/2 HP motor should be able to lift 400 lb. of door over a 8-10 second period and the weight is only when the door is fully closed. When it is half way up half the load is horizontal and not loading the motor.I got my car in that night and out the next day until the spring boy came to fix it again.
Best, Christopher
Point made. You don't remember....LOL
Home safes are a bitch for that, also. I usually write the combo on the back, in some binary notation and backwards.
3"Josepi" wrote:
Been there, tried that. The door did not budge.
Best, Christopher
It may depend on the type ( I had a screwdrive one), the HP and the clutch setting.
If you have your clutch (electrical, mechanical or both) set very sensitive for stopping when any resistance is "felt" (supposed to be a child or toy anti-squisher) the motor should give up right away as a safety concern. Mine may have been set tougher than yours??? Perhaps some only work in the closing direction???
The guy next door left a alum. lawn chair in his cheap uninsulated door, twice now....what a mess. The twisted and ripped panels have been replaced twice now....LOL. Obviously needs an adjustment of the safety setting.
Best, Christopher
Thanks for all the replies. It looks like I'll end-up going with a wireless unit after all, since it doesn't appear there are many other choices. I guess for the batteries, I could always wire-in an AC adapter.
I don't believe in hide-a-keys, false rocks, etc. They're too obvious of a hiding place, and where I live someone could spend a long time turning over rocks, or checking the usual hiding places, without being noticed.
Actually not a bad idea! :)
Yes, it's the locked outdoors without a key scenario, so going in another door would not be an option in that case. It's also good so that if I need to let someone get into my house when I'm away, I can always talk them through getting in with a keypad, so they wouldn't need to have been given a key ahead of time.
Like a pallet jack?
Perhaps, but I suspect is was more about the modest weight of your door. I called a garage door company in our area and he said the motors will not lift a heavy doublewide with a broken spring. FWIW.
Best, Christopher
Motorized, driver has a seat and everything. Like the ones the guys at home depot drive around the store. For getting the pallets off the top shelves.
It's also known as a fork lift.
Yeah - but that would make it too easy. Here they insist on splitting it up - the big ones they call fork trucks, the smaller ones are hi-lo's.
So when I made my little quip, I used the term I was used to - then it sort of took on a life of its own...
Update: I ended-up building my own keypad and wiring it to the KEP-1 control box via a 7-conductor cable. I found a 3x4 matrix keypad online, and created a mounting box for it. The keypad is supposed to be weatherproof, but the box I made uses an outdoor outlet cover, so it should be doubly protected from the elements. So now I've got something that meets my original requirements, even if I did have to create half of it to get there. :)
Good job!
LOL.... I love McGyver stuff.
