Elexol control modules
G'Day all,
I am looking at using an elexol IO24 CPU module which has ethernet and
24 I/O ports for control. Does anyone have any experience with this module?
Does anyone know of any other ethernet based embeded modules with at least 4-8 digital I/O?
Sid Young Australia
Sid
I guess it depends on what you want to accomplish but I think an embedded PC with ethernet, running DOS or Linux makes much more sense that a dedicated ethernet I/O board.
picoFlash has 16 I/O pins and there's an add-on board for 32 digital inputs,
20 digital outputs, and 11 channels of 12 bit analog inputs.
snipped-for-privacy@yahoogroups.com
Dave Houston
A dedicated PC per point is not economically viable for me, I need about a dozen of these modules on an ethernet link for 1 location and a few more for another. I intend on using a central node to do some agregation of data and if I can afford it a touch screen display to assist as a master control seperate from the PC, but I might just use another PC for that part of the system.
I'll have a look at the one you suggested.
So far I have elexol and modtronics as prime contenders.
Sid
Dave Houst>
Sid
The picoFlash costs $99 although you will likely spend $129 to get the development kit. The elexol board costs $124.
Dave Houston
